Yesterday I (finally) put Ceraballs under my Quad speakers and they do make a nice difference... only thing is I'm somewhow short three of the little bolts that fix the Ceraball feet to the speaker base.
So... I'm hoping somebody has 3 of the M6 to M8 adapter bolts spare so I don't worry everytime my dog bounds into the room. Also having all the feet fixed (there are currently 3 Ceraball feet just sitting under the speakers) will allow me to play about a bit with angles.
I'm happy to buy these of course I'm just not sure what moentary value they'd have. I have a few Pulsar Points spare if that's a good swap for someone.
Calling Ceraball owners!
Re: Calling Ceraball owners!
think i have a few of those bolts at home Ivor. I'll have a check later.
thanking yew.
They're the 'adaptor' bolts that change size half way up... thinner end (6mm?) to the speaker and thicker (8mm?) to the Ceraball itself.
yip, those ones I have. I have 8 of them (C below), one of which is missing a nut.
I also have a few M8 bolts if anyone is interested.
Yep, they're the ones in C. Perfect. I don't need the locking nuts as I have a full set of them. I don't how I'm missing those bolts at all... I guess it was an incomplete box in the first place.
I have quite a few of those 8 mm ones too if anyone needs them.
Can I arrange something with you during the week? I have your mobile so I presume you have mine?
Huge thanks Dave, much obliged.
PM sent Ivor
We're all sorted Fran... thanks. Huge thanks to Dave... top man.
Member of the Month Award goes to Dave F.
His picture will hang in the hallway of TirNaHiFi Towers for the next month.
Which one is Dave? He seems to have changed since I last saw him!
