phono stages....
jaybee
phono stages....
Post by jaybee »
So,
I've picked up a lovely Systemdek IIx 900
RB250 arm with a starter goldring Electra cart - to be replaced with a Grado MM at some point
Before I grab a Cambridge 551p, which seems a great little unit, are there others I should consider ( at that price point of <€100)?
bod
Re: phono stages....
Post by bod »
Keep an eye out for Musical Fidelity XLP-S. Should be able to pick one up for about €100 S/H. Very nice pre for the wonga.
jaybee
Post by jaybee »
cheers bod
can only see the x-lp on the market at the mo' I believe the lps is a good deal better?
bod
Post by bod »
Not sure of the differences as I only ever used the XLPS as opposed to the XLP. My friend has one. Don`t know if he still uses it. I can ask him if you like.
jaybee wrote:So,
May it bring you many hours of enjoyable listening.
Mark.
sdiesel77
Post by sdiesel77 »
I would recommend to get the Yaqin MS-22B for only 50€ over your budget.
It's a fabulous tube phono amp ! :)
http://www.ebay.ie/itm/YAQIN-MS-22B-Ste ... 3a78af39f6
jaybee
Post by jaybee »
markof wrote:
jaybee wrote:So,
Mark.
that's the plan!
of course its also just another avenue for haemorrhaging cash --- I'm already looking at upgrading wiring :-)
jaybee
Post by jaybee »
sdiesel77 wrote:I would recommend to get the Yaqin MS-22B for only 50€ over your budget.
do you not get hit with customs?
sdiesel77
Post by sdiesel77 »
You'd have to be REALLY unlucky. I ordered multiple times from outside EU and never had customs to pay.
Ask the seller to send it as a gift ;-)
bod
Post by bod »
Wiring upgrade is worth every penny. Full Litz loom on eBay is about €80. Fran did the work on my mate`s RB250. Totally transformed it. Highly recommended.
