Cheap speaker cable recommendations
Frankie Lee
Post by Frankie Lee »
I need to rig up my HT kit. I've run the cables for the rears into the walls. I just used the 79 strand cable from Pets at €2 a metre. Sound is fine from them. Now I have to do the fronts and centre and I'm going to need 43 metres for these so I can't afford to go crazy. Should I just run the same as the rears or should I save up and go for QED original or Anniversary stuff instead?
Or are there alternatives worth considering?
