Ok guys, I'm looking for a good second hand projector, has to be 1080p & of good quality. Preferrably InFocus IN83 or higher spec.
Will swap for some of my gear or buy straight if the money is right!
So, what have you? :)
WANTED: Home Cinema Projector
Re: WANTED: Home Cinema Projector
HI. what would you say for BenQ W6000 and 100" screen ?? Works perfectly.
What I say would be all dependant on price! :) How old, how much, what is the spec of the screen (electric, 12v trigger, make, gain etc?)marsko wrote:HI. what would you say for BenQ W6000 and 100" screen ?? Works perfectly.
Cheers,
Greg
