Turntable platter rotation speed mesure
sdiesel77
Post by sdiesel77 »
Hey Guys,
I was wondering if any of you had a digital stroboscope (or similar) to measure my turntable platter rotation speed ?
Cheers :)
S
sdiesel77
Re: Turntable platter rotation speed mesure
Post by sdiesel77 »
I have printed this paper strob disc but I don't know how to use it and not sure it's really accurate..
http://www.extremephono.com/ftp/50Hz.PDF
"Traditionally, speed testing of turntables has been done by viewing a series of bands on the turntable platter under mains lighting. The frequency of the mains supply (50Hz in Europe / 60Hz in the US) causes the bands to appear stationary at the desired speed and adjustment can be made using the turntables speed controller (if fitted)."
More info here
sdiesel77
Post by sdiesel77 »
cybot wrote:"Traditionally, speed testing of turntables has been done by viewing a series of bands on the turntable platter under mains lighting. The frequency of the mains supply (50Hz in Europe / 60Hz in the US) causes the bands to appear stationary at the desired speed and adjustment can be made using the turntables speed controller (if fitted)."
More info here
Thanks! I might need another tool then...
Rocker
Post by Rocker »
More info here
A flourescent lamp might be the answer but this is only a guess......
Beware of a thin chef!
More info here
Ordinary mains lighting worked perfectly for me....
More info here
Why would you need another tool? BTW here's another method (Fran mentioned it a while back):
Turntable speed : a simple calculation:
Time : 3 mins
RPM : 100
Reason:
TT runs at 33 and one third rev. per minute.
Therefore if you multiply 33 and one third by 3 = 100 rpm
So you simply set the timer for three minutes and the tt should revolve 100 times when the time is up.....Neat?
sdiesel77
Post by sdiesel77 »
Not a bad idea, actually I tried the printed stob disc under mains lights and it seems to work.
Now I have to check if I can or not change my motor speed, otherwise I might think about putting a variable R
sdiesel77
Post by sdiesel77 »
cybot wrote: Why would you need another tool? BTW here's another method (Fran mentioned it a while back):
Time : 3 mins
RPM : 100
Reason:
Tried this last weekend and worked perfectly ! It showed that my TT is rotating at the perfect speed :D
Thanks again :)
Time : 3 mins
RPM : 100
Reason:
Thanks again :)
Glad it worked out and you're happy :)
