Computer Problem
Computer Problem
Just before I take the laptop to the local repair centre am I missing something simple here? I'm using Windows 7 on a Compaq laptop and over the weekend it lost the ability to play video clips. If I click on a You Tube clip it gives me the following message "An error has occurred. Please try again later." I thought maybe I had lost Adobe Flash Player and downloaded it again, but still get the same message.
The antivirus is up to date, so I would be disappointed if something had slipped in under the radar there. Any ideas?
Re: Computer Problem
What browser are you using? Is it happening with all of the usual suspects?
Thanks for that Simon! I switched to Google Chrome from Mozilla and everything worked again. That leaves me disappointed with Mozilla, I used to think that it was great. Thanks again!
I swap back and forth, but I've been using chrome for a while now. Glad it's working anyway!
