anyone tried those eBay t amps?
jaybee
Post by jaybee »
my amp is being exited from the living room as the sky remote and harmony one keep making it do random things ( change source, balance etc) I'm going to pop a cheap 2ch amp in for the tv and thought one of those tiny eBay tamps might do the trick....
Re: anyone tried those eBay t amps?
I've never tried them, but I was thinking about them only recently and wondering what they sound like. Will they powerful enough to do anything with your speakers?
paulb
Post by paulb »
i have one for free if you want it...bit cosmetically chalenged as i took it out of its case but works fine.let me know
jaybee
Post by jaybee »
the English made one with 2024(?) chip is 25wpc so fine for normal tv!
or maybe this one....
http://www.ebay.ie/itm/Topping-TP32-T-A ... 3017wt_776
jaybee
Post by jaybee »
paulb wrote:i have one for free if you want it...bit cosmetically chalenged as i took it out of its case but works fine.let me know
That'd be brilliant paulb!!
jaybee
Post by jaybee »
cheers paulb... absolute gent!!
I'll let you know how it goes!!
Johnny
jaybee
Post by jaybee »
properly impressed... my speakers (monitor audio mini monitors ) are not sensitive 87dB I believe, I don't know if sensitivity is logarithmic in the same way as sound pressure?
This tiny little thing is driving them really well, and it could just be the switch over from a few days of built in tv speakers only, but there seems to be a lot more bass than when my primare was driving them!!!
Must plug in the cdp next!
paulb
Post by paulb »
you have the perfect speakers for this amp....i got the same resoults with small speakers, more bass, it doesent sound that good with bigger speakers all that bass gets loose...it is only 5 watts..
