My new amps arrived on friday.
Im delighted with them. It took me a while to find what i was looking for as it had to fit into my Tv stand as well as suit my needs sonically. I bought them second hand from a dealer.
Its amazing what some real power can do to a loudspeaker, especially my Insensitive ATC's.
The power amp is rated at 215w/ch@8ohm's, 430w/ch@4ohm's and can put over 60amps peak current into a 1ohm load.
The power amp uses a switch mode power supply.
Here's a review i found on them http://www.terrason-audio.nl/cms/files/ ... review.pdf
Chapter Audio Preface+ & Couplet
Arcam Cd33, Vdh The Integration, ATC CA2, Gotham GAC-2v1 XLR, ATC scm50asl
Re: Chapter Audio Preface+ & Couplet
Best of luck with the new gear Matt....I hope that you get many pleasurable hours of listening from the new purchases!!
Thanks Fergus
Im waiting on a Hifi Tuning fuse for the Ac inlet on the pre amp at the moment. The power amp doesn't need a fuse as it has a resetable switch fuse on the rear panel.
Hi Matt
I have been offered a good deal on a preface and couplet combination and if you don't mind would be very interested to hear your view on the combo since you bought it. Also which speakers would you recommend?
