FOR SALE ROTEL RMB 1095 POWER AMPLIFIER
For Sale/Wanted
mars
Post by mars »
FOR SALE ROTEL RMB 1095 5 CHANEL POWER AMPLIFIER ,
IN VERY GOOD CONDITION, Producing a full kilowatt (1000 watts!) of output power, Rotel's RMB-1095 is a stunning realization of Rotel's capabilities in amplifier design. It is, for all intents and purposes, a multi-channel version of the RB-1080 stereo power amplifier, already recognized as one of the finest amplifiers available at any price from any manufacturer. Rated at 200 watts per channel (all 5 channels driven into 8 ohms, 20 Hz 20 kHz, less than 0.03% THD), the RMB-1095's power supply is built around two 1.2 kVA toroid transformers. Eight 15,000 uf British-made BHC slit foil capacitors provide prodigious storage capacity and combine with 30 150 watt/15 amp output devices for uncompressed reproduction of the most dynamic source material. A sophisticated "over current" protection circuit with front panel LED indicators guards against potentially harmful operating conditions. Special "current absorbers" minimize turn-on surges while gold plated balanced XLR and single-ended RCA inputs provide easy connection to a variety of controller/preamplifiers. Heavy rear casters assist in placing the amplifier. SELLING FOR 750
MORE INFO ON http://www.hometheaterhifi.com/volume_7 ... -2000.html
or swap to Bel Canto mono amplifier.
willsandbills
Re: FOR SALE ROTEL RMB 1095 POWER AMPLIFIER
Post by willsandbills »
could you sen me any pics of the amp? also wherabouts are u located. Lastly do you have original packaging ??
mars
Post by mars »
Hi.
I'm located in Mallow Co.Cork, i will put photos later, an amp is great condition it self, i was using to drive my cremona auditors and centre Chanel, but decided go for monoblocks ,the amp is in black color, and i do have original manual and original box.
Here its a link for a pictures http://www.adverts.ie/home-audio/for-sa ... 95/1424749
