Yes, you are not mistaken!!
I'm looking for a short term loan of a VHS player so I can transfer a few key videos over to digital.....
I had one kept, but hadn't used it in a few years. When I fired her up turns out the main head bearing/motor is very stiff and its not playing right. Its not worth fixing, and I have a few VHS tapes I would love to transfer over.
Anyone with one they're not using for a week or 2 that I could borrow?
pretty please?
looking for a loan of a vhs player
Re: looking for a loan of a vhs player
Hi Fran, I have two floating around. You are more than welcome to borrow the only issue is confirming where they are, as I am in the process of moving house. Also will struggle to get it down to you at the moment.
I have one boxed away somewhere in my attic and if you do not get one quickly Fran come back to me and I will try to dig it out for you to borrow.
I have one or two here as well. They haven't been used in years but should be ok.
I have one here too.
Hi Fran,
Have a panasonic nicam stereo in the attic (was the bee's knees in its day) and can drop off as i need an excuse to hear those new horn speakers you have built.
Linn LP12, Ittok, Dynavector DV-20X2L, Lehmann Audio Black Cube, Arion Audio 300B, Living Voice Auditorium
naasbiker - that sounds like a plan. You're so close to me its probably the easiest option!
Thanks to all!
Thanks to all!
