there a little less square but id like to try proper value caps before saying too muchrandytsuch wrote:How does the cap divider look with your scope?nige2000 wrote:
transformers were used in series with a dc blocking cap in paul pangs clock modules
i disliked its effect as it lacked detail compared to been direct but it sounded smoother which is probably likable to some
on the scope it changed a cleanish square wave into a sine wave
actually so far ive preffered a square wave as long as there isnt significant preringing
DIY Regen Battery tweak
Re: DIY Regen Battery tweak
if you program it to take a 24 mhz clkjkeny wrote: Reprogrammed - so the whole firmware has to be done, not just tweaked like hardware - it's not like the firmware can be downlaoded & reprogrammed & DiYinHK or any XMOS DAC manufacturer will give away the source.
Still, it's not impossible, just takes a bit of time
still need a clk that takes a 1.8v ps
ive good 24 mhz tcxo but wont operate at less than 3v
so a 24mhz ndk would fit the bill if they were freely available but dont see them anywhere
hope i dont jinks myself but ive a diyinhk and usb hub/frequency divider ff running the 48mhz clk at 3.3v levels and playing music for the last 36hrs non stop
so if we could programme for 24mhz were on the pigs back as long as xmos stays reliable that is
i failed to get the 100/130pf caps to work im thinking its lack of current
So, you're running the XMOS with a 24MHz clock signal but it's at 3.3V & NOT 1.8V as before?nige2000 wrote:hope i dont jinks myself but ive a diyinhk and usb hub/frequency divider ff running the 48mhz clk at 3.3v levels and playing music for the last 36hrs non stop
Any audible difference running it this way rather than with 1.8V 24MHz clock signal?
still workinjkeny wrote:So, you're running the XMOS with a 24MHz clock signal but it's at 3.3V & NOT 1.8V as before?nige2000 wrote:hope i dont jinks myself but ive a diyinhk and usb hub/frequency divider ff running the 48mhz clk at 3.3v levels and playing music for the last 36hrs non stop
its 48mhz 3.3v level to xmos and 24mhz from ff at 3.3 v levels to usb hub
i had assumed if i put in 24mhz in to xmos without programing it would either not work or play at half speed
ill try a 24mhz before i fit it to the soekris just to see what happens
ive it running on a pcm5102a for testin and sounds pretty damn decent although not the same natural sound as the r2r
a good tight detailed snappy sound, timings probably improved over the other front ends ive heard on this dac
no neg effects so far and must be playing a few days now non-stop
Sorry, yes, I meant 48MHz to XMOS - I don't think 24MHz will work without programming the XMOSnige2000 wrote:still workinjkeny wrote:So, you're running the XMOS with a 24MHz clock signal but it's at 3.3V & NOT 1.8V as before?nige2000 wrote:hope i dont jinks myself but ive a diyinhk and usb hub/frequency divider ff running the 48mhz clk at 3.3v levels and playing music for the last 36hrs non stop
Great, sounds very promisingive it running on a pcm5102a for testin and sounds pretty damn decent although not the same natural sound as the r2r
The "journey" continue:nige2000 wrote:heres my 2nd attempt at it
nice improvement in clarity
I just temporary taped until I see if it works (if I didn't break something).
The idea is to taped hole body with cooper tape, or some EMI stuff.
Again, BIG thanks to Nigel! ;-)
Any headway on the programming?
Have you not tried it yet?
Like Hitchcock, he's building the suspensenige2000 wrote:Have you not tried it yet?
