grisaia
Post by grisaia »
sbgk wrote:tried to simplify the install
download mqn haswell.zip
extract the files to c:\musicplayer
if you use another directory change the directory in mqn.bat
@echo off
cd c:\musicplayer
Title MQn - Just good music
then double click setupmqnparam.bat and close the window manually
decide which version of mqnplay is required win 10 or w2012 r2 (also works for win 8.1)
rename the selected mqnplay.exe and mqnloader.exe and mqncontrol.exe files so the description suffix is removed
select wav files/copy to clipboard and double click mqn.bat to play the music
more details on how to play non wav files here
http://randytsuch-audio.blogspot.co.uk/ ... setup.html
Do we still have to use hex editor to modify device string?
@echo off
cd c:\musicplayer
no, the above steps is all you need to do.
the device string is stored in mqnparam.txt which is created/overwritten when you run setupmqnparam.bat
218/91/72
Bass is too fat and out of balance to other tonal ranges and becomes too overpowering.
217/89/70 was better balanced
Aleg wrote:218/91/72
did you try 217/90/71, have put them back up ?
217/90/71 isn't so overpowering, but still prefer 217/89/70.
In 90/71 the bass becomes less distinct, loses some of the definition that is so nicely present in 89/70.
Am using Schubert Rosamunde string quartet played by Alban Berg quartet, and listen to the balance between the first / second violin and the cello. The cello has a clear role but with 218 it overpowers the first/second violin and disturbs the balance of the piece.
ok, thanks
tried a rewrite program and managed to get a reduction in treble. Shall try and get a good version and a bad version. The bad version can be used for testing regenerators etc, if the treble is restored then the regenerator is working. If the regenerators can't restore the treble then there is some other mechanism at work that affects the sound.
janh
Post by janh »
Aleg wrote: 217/90/71 isn't so overpowering, but still prefer 217/89/70.
+1.
217/89/70 is very fine, giving a nice sound.
building on v217, v219 is more free flowing, sounds good with jazz, anyway.
sbgk wrote:building on v217, v219 is more free flowing, sounds good with jazz, anyway.
Get an application error with mqnloader v73 at instruction 0x4000103b referencing 0x09d87000 memory could not be written. Only loads first track.
Is on win 2012r2
