Soekris Dam Dac
Re: Soekris Dam Dac
Getting part numbers wrong is like something I'd do
These type chips usually have 74 in the title
Still have Richards buffer to implement yet
wyan
Re: Soekris Dam Dac
Post by wyan »
randytsuch wrote: Sat Sep 30, 2017 3:43 pm Do not use a 373. Made a mistake :(
Need a 374. Or two 74s. But the 374 will be easier to use for this
No worries and thanks. I was getting the 374 as linked in previous posts. Cheers. :)
randytsuch
Re: Soekris Dam Dac
Post by randytsuch »
Looks like new firmware, and new filters are on the horizon
http://www.diyaudio.com/forums/digital- ... ost5377384
My DAC now has potato flip flops and the isolators removed. Sounds really good.
Re: Soekris Dam Dac
randytsuch wrote: Tue Mar 20, 2018 12:02 am Looks like new firmware, and new filters are on the horizon
Doubt we will see anything out of that for a while
anyone know what happened to Paul the moredamfilters guy
Like to compare analog filters to digital sometime
Hopefully get to do some 1121 stuff soon
gstew
Re: Soekris Dam Dac
Post by gstew »
I remember seeing schematics, diagrams, and pictures of this, but can't find them now. Can someone point me to them?
TIA!
Greg in Mississippi
randytsuch
Re: Soekris Dam Dac
There are some pics buried in this thread somewhere, by Nige.
I added a couple pics to my blog, and started an update to explain this last change.
Work in progress, take a few days to finish because I need to figure out what I did lol
Randy
randytsuch
Re: Soekris Dam Dac
Blogs updated to add my latest changes.
Take a look, and please let me know if it makes sense.
gstew
Re: Soekris Dam Dac
Post by gstew »
Randy,
That is good and I can duplicate from your blog updates. With the SDTrans384, I need to confirm whether the LC245A at the output of the I2S lines is doing reclocking or is just a line driver. If it does reclocking too, then all I need to do is bypass the isolator chips.
MANY THANKS!!!!
Update... looking at the SN74LVC245A datasheet, I don't see a clock input, so this may be a good reclock point. Will check with Bunpei.
My other Soekris is fed via an Allo.com Kali reclocker on top of an RPi.
Nige, how did your experiments with a fixed-rate clock into the Soekris FPGA work out? AND weren't you trying the 1121 at some point?
Greg in Mississippi
Re: Soekris Dam Dac
gstew wrote: Thu Mar 29, 2018 4:58 pm
i know I've been bad and made no progress, the amp building have been quite the distraction,
ive actually just received a new si514 to put on that soekris,
as i pretty much failed to get the fixed clock to work at least not stabile
i hope to revisit the fixed clock thing again
ive looked at the 1121 yesterday, so maybe ill do something soon
Re: Soekris Dam Dac
On the 1121 has anyone anywhere done any mods?
So far I've located the vref regs the mute transistors
On the digital side two regs I assume 1.2v and 3.3v
I see there a clock input lvds that goes direct to the +/- pads of the si514 I assume you just disconnect the power to the oscillator to enable external clocking
The fpga caps are so tiny I couldn't be bothered
Other than that it looks relatively simple to do
Ideas as always welcome
Nige
