Nigel nailed! :) :)nige2000 wrote:emi/rfi, anti vibration and resonance control :)tony wrote:That looks incredible Adam. Mad but incredible!
What machinery are you using for the shapes?
Will have to go over the build again but you seem to be earthing lots of sections? Is that to the mains earth?
It is probably obvious stupid question.
What is the logic with all this is it to ensure a really good earth? It is not grounding?
oh and looks at a guess
Thanks Tony,
I had a friend "shaping" the corners of the two 2x2 aluminum bars from the face-plate.
The rest of "machinery" are a wooden saw with blade for metal, drill, grinder and a lot of twisting (for treads).
I earthed the box from the Tellus/separate ground combo.
For the PPA clock and cpu plug I made those:
I connected them to the earthed box. I had similar in my previous PC and they work. I guess that they work like the Faraday cage.....no crap in no crap out!
For the 24 pin, usb plug and sata I did similar, just a bit different!
Now I'm just playing with adding 3M pieces and more brass on the inside! :) :)
