possible to alter the autokeyscripts to point to/work with mqn ? anyone want to try ?
http://jplay.eu/forum/computer-audio/fo ... aymini-v1/
uploaded control 4.19 avx2, more optimisations, hopefully some improvement
4.20 probably best, amazing how the method of loading the data affects the sound.
sbgk wrote:possible to alter the autokeyscripts to point to/work with mqn ? anyone want to try ?
Although initially it appealed in concept, I was wondering what benefit this would bring?
Positive - the ability to use the Foobar UI to browse & select a playlist
Negative - I don't see how Foobar could control MQn, as there is no control to control! It is control of Play, Stop, Back, Next that I would welcome.
If correct, then I don't think it is for me. Or have I missed the point [not for the first time]?
even a journey of a 1000 miles begins with a single step.
Please correct me if I'm wrong!
Was the latest version that played the 24/88.2 format the combo: mqnplay2488.exe 24 bit 7.41 avx2 + mqncontrol 3.65 + PA v94 avx2?
Now you are Playing with me. Do Stop. Or I will come Back to you Next.
9.10avx2ciunas and 4.21control. Great depth of detail clarity. Have an SSD belonging to Pearse found it in a box as you do! Tried it to see if it would boot in IDE(no joy) but the version of MQn was a good bit older. Really big difference when I switched back to my SSD and latest MQn. Eh! can I do the request for multiple versions of this latest one for Scalford? Big7 is going and a herd of assistants for Pearse. Hopefully you can pop along Gordon?
sima66 wrote:Please correct me if I'm wrong!
Hi Adam yes found it tonight 7.41avx2 I have 3.64 with it and portaudio v64 for me. Will have a go with your settings
2channelaudio
Post by 2channelaudio »
Hi Gordon,
Any idea when the majority will be able to try the latest versions of Mqn on their devices?
Keen to have a listen with my yellowtec puc 2 lite.
Clive
Post by Clive »
2channelaudio wrote:Hi Gordon,
Me too with my Octave mkII (M2Tech USB card).
