Pearse try 2.61
see if theres something in it you like
you should try some of the funky bios settings too as an experiment
Flicked around for awhile tonight on some of the 60's but not the mad named ones but settled on the latest as per Pearse above. Now with sbgk working fervently on 24bit I think this will work for me. If no further progress is made it don't matter. Unless Gordon comes up with some streaming mechanism that needs cat7 cables etc my meicord will be used for routing duties around the house.
DaveF (I guess I know where the "F" came from), I did not ask you to understand (I don't), TRY IT! It only takes two seconds. Much less than writing your "opinion" on that.DaveF wrote:I dont post on the wam.tony wrote:Did I not answer that question nicely Dave? Your not on the wam now!DaveF wrote:renamed files and directory structures sounding different????
A whole new level of fuckwittery has entered Computer Audio! Sorry guys but that idea is probably one of daftest I've ever heard in hifi.
Excuse the manner of my post above but the concept is pretty out there when it comes to whacky ideas! Think about it, renaming a file somehow causes a chain of events so as to change the signal out of the DAC? I'm all for exploring new ideas/concepts but a reality check is needed now and again. This is a public forum so any wild bizzare claims cannot expect not to go unchallenged.
The point is not in "renaming", it is to use only one number or letter in the name (the shorter name (path) the better sound, no folders, or sub-folders, just straight from the C drive.
I guess that all of you who are making fun of the PFM, are nothing better than them!
Just give it a try before you comment on something, because there might be some other things that you don't know about it. Just because you can't understand or make sense of something, doesn't mean that it doesn't work. Not everything can always be explained or understood.
My computer knowledge, from 1 to 10, is around 0.02 (isn't that obvious), but on Marcin's (JPLAY) suggestion I tried this and I liked the difference.
Since we all look for improving the sound (or maybe not), I thought that this tip might be useful. I'm sorry if I raised so many "scientific" explanations and oppositions.
It was just simple advice to try. Take it or leave it, I don't care.
I guess that all of you who are making fun of the PFM, are nothing better than them!Sima66
Ouch that hurt. Hope nobody has got to that point. There are 16k+ punters on PFM and lots of nice people.
But if you read the threads on computer audio on that forum 5-7 people descend and mayhem ensues.
If anybody 'laughs' at that here that is instead of going mad with frustration at the carry on.
Very much hope you are not taking that vibe here. My answer was honest but I do agree with you everything should be tried before either condemning or passing an opinion.
My honest view is that it is the cumulative things being discussed that work. There are some big hitters I just passed a remark that I think it is possibly at the low end.
Don't forget Marcin waxed lyrical about the Musica Ibuki dac and various other things. We all change our minds over time and with new info or direction truisms can change.
I apologize if I was misunderstood or unintentionally offended anybody! That was never my intention.tony wrote:I guess that all of you who are making fun of the PFM, are nothing better than them!Sima66
My point is that this same guys who are commenting on this matter without trying it, where laughing at PFM for doing the exact same thing (commenting on MQn without trying it).
If you want to try this with my Autohotkey-Jplay-script : it is still here :sima66 wrote: DaveF (I guess I know where the "F" came from), I did not ask you to understand (I don't), TRY IT! It only takes two seconds. Much less than writing your "opinion" on that.
https://dl.dropboxusercontent.com/u/907 ... cript2.txt
(I could adapt it for MQn, if there is lots of demand)
The script will copy your selected flac or wav file to (a) root dir with the name .flac or .wav (that's right No name, Only dot-extension) and then start Jmini.
I played around with it for a while, thought that it gave a little improvement in overall dynamics on my Quad ESL, but not that much of a difference that I kept using this cumbersome procedure.
The improvement in SQ obtained by replacing the Exporer-shell in W8 with TotalCommander was more noticeable.
dont worry sima66
all sorts of weird stuff sometimes matter
ill test it soon
ill test it soon
Does anyone know a freebie Flac converter? Why can I never find the free ones?
Peter not for me I got a reality check tonight when my wife laughed at the copying and opening of files. Then mqn.bat and then command prompt screen etc. So any more complication will not be appreciated here! Maybe people should try it first. Will have a go think I have done it already with test tracks loaded on usb stick for testing but will go back again and really listen this time.
Listening away to music and letting albums play all the way through. Live boot leg from soundboard sounds great. Keep saying it but it is hard to see how it gets much better with the equipment I have.
It is the embellishments that are needed now. A version that requires just a nod from the wife to start up her favourite Pink Floyd albums while firing over a pair of ear defenders to my seat is top of the list
I fully intend to try out MQN once my windows PC is back in operation.sima66 wrote:I apologize if I was misunderstood or unintentionally offended anybody! That was never my intention.tony wrote:I guess that all of you who are making fun of the PFM, are nothing better than them!Sima66
As for my "opinion", I have enough technical knowledge to know that its highly unlikely that placing files in the root etc could change sound quality. I'll try certain things if I think there is a technical explanation/reason behind no matter how small but this file thing is stretching it a bit for me.
Not sure what you meant about the F in DaveF but I can take it so no worries. :-)
that what i would have thoughtPeter_T wrote:If you want to try this with my Autohotkey-Jplay-script : it is still here :sima66 wrote: DaveF (I guess I know where the "F" came from), I did not ask you to understand (I don't), TRY IT! It only takes two seconds. Much less than writing your "opinion" on that.
if there is a difference its small
but its interesting
