Like
Yes
22
100%
No
0
No votes
Total votes: 22
randytsuch
Post by randytsuch »
nige2000 wrote: Tue Oct 31, 2017 4:17 pm I'm lucky so far I Dont really need magnification
But I'm sure that in a production environment industrial spec magnifiers would be quite the time saver
You can do fine pitch SM chips without magnification? I need proof lol
I can barely do them with magnification.
frd1996
Post by frd1996 »
I can do 603 without magnification - no problem. I did a couple of 402 but with a good daylight. I guess positioning them is the tough part. Once you hold them properly in place it gets easier. Also, BGA balls can be used to take just enough of solder on your soldering tip.
F
Ok amp assembly starts Saturday if enough amp crew are available
another day of madness............
we got batteries installed in 5 cases
and got transformers heatsinks and psu units in two of them
and almost the same in a third
these psus where tested and set to the appropriate voltage
Great work guys.....
Very impressive!
I miss "piece of the action"! :)
Another 2 good weekends work and finally taking shape.
We have 3 amps close to finish now so hopefully another couple of get together s will finish these and bring the remaining amps to to finish line.
Some pics below.
PeterK
Post by PeterK »
Well done, I would have loved to have done this, maybe next time if you aren't put off! Those amps look the biz.
lol.. next time
we were joking before about calling it the "never again" amp
it really turned out to be quite a lot of work to get the quality and cosmetics we way we wanted
the case work seems to be far more time consuming than the electronics
hopefully all involved will we happy with their amps when there all finished
and be able to sit back and say we built it and it sounds great
