Sligolad wrote:
nige2000 wrote:got another go with 4.12
it can make me forget about lots of versions as its better at
cymbals,
triangle,
brushes
tambourine
whistle
clapping
lots of hard stuff
old reliable "you look good to me : oscar peterson" left me in a bit of a trance for a couple of minutes after it ended (in a good way)
probably the tightest bass to date, maybe the best at handling fast moving music
Nige when you post 4.12 are you referring to avx or sse versions?
I am guessing avx given what you are hearing...
Cheers, Pearse.
Yes the avx's with the 512 control
I haven't tried the sse4s
Avx versions always seem to be ahead so far?
Anyone else get them working yet
I'll re upload later incase I messed it up last time
Wonder if it's something to do with the handling of the files the way we copy etc
cvrle59
Post by cvrle59 »
None of these new avx versions works on my system, including 4.12.
BTW, they'd better be better than 3.14...
cvrle59 wrote:None of these new avx versions works on my system, including 4.12.
George
Try to download Pearse's (Sligolad) dropbox directory a few pages back.
Running from that directory using his mqnload worked immediately in my case. Don't copy files to other directories because with me they no longer worked. But from Pearse's directory just fine, also after copying new releases.
cvrle59
Post by cvrle59 »
George
I'll give it try tonight...thanks!
DJ le Roi
Post by DJ le Roi »
Thanks Sligolad for your MQN folder. For the first time I can listen tot AVX versions and I like them.
One question: When I choose MQNload I get the following message:
Could not find c:\MQNLatest\Data\mqnplay.exe
The operation completed successfully
The system cannot find the file specified
After this message I hear music.
Is this normal? Or, do I make a mistake?
DJ le Roi wrote:Thanks Sligolad for your MQN folder. For the first time I can listen tot AVX versions and I like them.
This is normal and can safely be ignored.
Taggart said to remove the cause once the mqnplay is final.
4.12 the bad bits
high frequency seems to be a little capped we lose some of that 3rd dimension, air, atmosphere etc over the 10ms avx's
bass for me seems a little much by times and a little boomy on some notes
10ms?
great version all the same much is good and better
Rich vein of form Gordon, 4.15 avx it well ahead of 4.08 avx, really surprised how much deeper it digs.
Really enjoying what I am hearing this evening...the new top MQNPlay.
Only listened with MQNControl 1024 so far but sounds great.
Cheers,
Pearse.
Sligolad wrote:Rich vein of form Gordon, 4.15 avx it well ahead of 4.08 avx, really surprised how much deeper it digs.
Cheers,
Pearse.
better than 4.14 ?
uploaded 4.16, slight tweak to 4.14, find 4.15 kills off some of the atmospherics.
2channelaudio
Post by 2channelaudio »
nige2000 wrote:4.12 the bad bits
10ms?
I thought the bass was great.
More weight, punch and clarity
I never found it boomy.
For me, 4.12 has the best bass I have heard from mqn in a while
I think its important we compare back to 10ms to make sure we are on the right track.
