Clive
Post by Clive »
jesuscheung wrote:clive, my post is outdated. has incorrect information.
try vs2013pro
and uninstall the junk exactly as it is in the screensthot:
http://blog.sina.com.cn/s/blog_72b3301c0100q2b2.html
e.g. uninstall more than needed e.g. .net framework will decrease SQ.
works for 7,8,R2,2012,8.1.
yes, this tweaks originates from pkshan
EDIT
before you install vs2013pro, uninstall all C++ redistributable first, otherwise, this tweak is worthless.
EDIT2
because overwrite existing C++ redistributable with another copy will decrease SQ.
I see it costs £303 in the UK......:-(
vs2013pro activation key is same for everyone and is public....
not like win8.1/office that needs activated online....
vs2013 doesn't fix any OS jitter anyway
it is not essential
disabling firewall, antivirus is more important.
try desktop wallpaper vs desktop solid color.
when you can tell difference, you know what OS jitter is.
Clive
Post by Clive »
jesuscheung wrote:vs2013pro activation key is same for everyone and is public....
I think I know what you mean....I can't take the risk of being audited.
priority should be fixing jitter over install vs2013
for example, small icon vs large icon in desktop. which is better?
Clive
Post by Clive »
jesuscheung wrote:priority should be fixing jitter over install vs2013
I wasn't even thinking about SQ, it's the evelation issue I hit at random. Yesterday I fixed it quite easily by setting EnableLUA from 0 to 1 then back to 0 and rebooting just the once. MQn then ran fine.
pray to god... god created all digital rights
Clive
Post by Clive »
jesuscheung wrote:pray to god... god created all digital rights
The software company I work for doesn't see it that way, pirate software even on personal machines puts my job at risk.
is the evaluation copy of r2 not ok?
damn rabbit hole anyway
hard to stop tweaking
Clive
Post by Clive »
nige2000 wrote:is the evaluation copy of r2 not ok?
Eval and 30 days trials are ok for sure. I don't want to do too much tweaking but I'd sure like to not need to frig EnableLUA all the time just to get 8.1 to run MQn.
