jorm
Post by jorm »
Yes,3.39 sse2 is the the new top pick .3.39 avx crackles here too.After a fresh R2 install I have 24/96 also through my AP2 both with driver 1.16 and without.
Retested this morning 3.39 sse2 mqnplay2496.exe with thesycon 1.67 and 2.20 drivers and they now perform just fine.
jesuscheung wrote:
sbgk wrote:JC, there's an interesting debate about mmcss settings and whether they change only at mmcss service start, I think they do, but I'm sure we've all thought there was a sound difference after changing them via regedit without restart.
the solution seems to be to have a proaudio setting for each bitrate sample rate combo eg pa1644 etc
actually, now you remind me of sample rate....
for playing say 96khz
if you change clockrate, you have to change my DAC to 96khz too
my DAC is set to 44100. it doesn't switch sample rate by itself.
EDIT
i also use reclock software. that is set to 44100 too... sh*t...
a lot of things need changing for playing hires
lol
every sample rate is a project on its own
crackling on the new avx here too
there is a bug in the 3.39 avx
have uploaded 3.39 no pre buff sse2/avx versions, think they might be better than 3.39
a bit harsh sounding
taggart
Post by taggart »
3.39 no pre AVX works now. Thanks Gordon!
I seem to prefer the avx 3.27 to avx 3.39 no pre. It has more shine to it.
Only a short listen though
uploaded 3.39 avx with bug fix
and 2 other versions, but think 3.39 is better
uploaded 24/96 avx 3.39 bug fix as well
Karl
Post by Karl »
Hello Gordon,
the older reference 2.62 sse2 plays 16/24 bit with 44.1/48/96.
Hope the new 3.39 sse2 can do this soon.
best regards
Karl
Karl wrote:Hello Gordon,
best regards
Karl
what can you do for me Karl ?
Karl
Post by Karl »
Hello Gordon,
nothing at all.
Stop, wait.
I want to test on a second DDC, which only works with 24bit.
My two DDCs have different sounds, so I am very interested to know, whether the 3.39 is the final version at all.
I think this job I do for you.
best regards
Karl
nothing at all.
Stop, wait.
best regards
Karl
for you it is the final version
