There is a fine Walter Weller/London SO/LPO set that comes around on budget labels now and then, quite good. Will have to check out the Kitajenko/Prokofiev however.fergus wrote:Cheers Seán. As Kitajenko did such a good job with the Shostakovich symphonies I will put his Prokofiev cycle in the Ponder Pouch.Seán wrote: I do have the Kitajenko/Gürzenich Orchestra Cologne Prokofiev cycle Fergus and I really like it. I also have a few recordings of Prokofiev's music performed by the LSO under the direction of Previn and they are marvellous too.
What are you listening two?
The Weller set is available on the Brilliant Classics label under license from DG. I have often wondered about the set and if I should get a copy of it.DonKC wrote:There is a fine Walter Weller/London SO/LPO set that comes around on budget labels now and then, quite good. Will have to check out the Kitajenko/Prokofiev however.fergus wrote:Cheers Seán. As Kitajenko did such a good job with the Shostakovich symphonies I will put his Prokofiev cycle in the Ponder Pouch.Seán wrote: I do have the Kitajenko/Gürzenich Orchestra Cologne Prokofiev cycle Fergus and I really like it. I also have a few recordings of Prokofiev's music performed by the LSO under the direction of Previn and they are marvellous too.
They are not to everyone's taste, that's for sure. I have just finished listening to the Fifth and am now on the Sixth. I must say I do enjoy these works:fergus wrote:I have not listened to that set in quite a while. I always found the later symphonies to a bit inaccessible however.Seán wrote:
Bohuslav Martinu
Symphony No. 3 & 4
Bamberg Symphony Orchestra
Neeme Jarvi conducting.
Hugely enjoyable. I am particularly fond of the Fourth Symphony.
Bohuslav Martinu
Symphony No. 5 & 6
Johannes Brahms
Ein deutsches Requim op. 45
La Chapelle Royale. Collegium Vocale
Christiane Oelze (Soprano)
Gerald Finley (Baritone)
Orchestre Des Champs Élysées
Philippe Herreweghe conducting.
Johannes Brahms
String Quintet in F major, op. 88
String Quintet in G major, op. 111
Amadeus Quartet
Cecil Aronowitz - Viola II
Ludwig van Beethoven
Symphony No. 4
Berlin Philharmonic Orchestra
Claudio Abbado conducting.
The Weller Prokofiev has long been highly regarded and the Brilliant Classics set is the one I have.
And thanks to you all, I am listening to the Kitajenko Gürzenich Orchestra Cologne Prokofiev 6th now on Spotify. A most fine performance of a brilliant symphony, all too little heard.
Inspired by Don:
Serge Prokofiev
Symphony No. 6 op. 111
Gürzenich-Orchester Köln
Dmitrij Kitajenko conducting.
This is a fabulous performance by a great orchestra and is beautifully captured on disc. To my mind the Sixth Symphony does reward repeated listening. No less a figure than Myaskovsky said of it: "I only began to understand and appreciate [op. 111] after hearing it three times. It is profound, yet somewhat orchestrated austerely."
Serge Prokofiev
As for the Shostakovich cycle, the symphonies arranged for a larger orchestra were recorded live during concerts, and thus the Kölnische Rundschau printed the following review of the performance of the symphony no. 6:
“This symphony written in 1947 is generally regarded as unwieldy; an ungrateful task for musicians as well as the audience, and it is therefore rarely played in concert halls. Kitajenko, however, manages to decipher the score by unfolding it as a tragic, psychological chain of events, instead of as a revoltingly noisy scenario from Stalin’s era. Melodious string passages repeatedly occur in an almost elegiac manner. Flutes and horns unearth unexpected and surprising elements of beauty, as it were – even though this was only possible because the musicians summoned up all possible purity of sound and musical ardour.”
Franz Schubert
Symphony No. 8
Karl Böhm conducting.
This is a superb performance, I love it. I really must get more recordings of Karl Böhm's work.
That is a work that I really like; I must do a listening project on it some time.Seán wrote:
Johannes Brahms
