I'm about to make a new version of mqnload that has tasker functionality intergrated. And several more functions ...Aleg wrote:I know, but I want to be able to apply tasker commands after running mqncontrol and I can't do that when using mqnload, unless I call mqnload from within a batch that comtinues to run tasker.
still preferring the 2.3's
seems like the highs are restricted, sounds flatter than it should
That sounds really interesting, esp. because a solution where tasker runs in a batch after mqnload, might be difficult to accomplish as it is unknown when mqnload has finished converting flacs and actually starts mqncontrol and mqnplay.taggart wrote:I'm about to make a new version of mqnload that has tasker functionality intergrated. And several more functions ...Aleg wrote:I know, but I want to be able to apply tasker commands after running mqncontrol and I can't do that when using mqnload, unless I call mqnload from within a batch that comtinues to run tasker.
So looking forward to a new extended tasker.
I'm planning on having parameters for mmcss clock rates, win8.1 switches, priority and system timer which will be held in a text file read by control.taggart wrote:I'm about to make a new version of mqnload that has tasker functionality intergrated. And several more functions ...Aleg wrote:I know, but I want to be able to apply tasker commands after running mqncontrol and I can't do that when using mqnload, unless I call mqnload from within a batch that comtinues to run tasker.
Good to know! Think we should talk about that in detail. I'll send you a mail tonight.sbgk wrote:I'm planning on having parameters for mmcss clock rates, win8.1 switches, priority and system timer which will be held in a text file read by control.
why is there problems with this ?sbgk wrote:I'm planning on having parameters for mmcss clock rates, win8.1 switches, priority and system timer which will be held in a text file read by control.taggart wrote:I'm about to make a new version of mqnload that has tasker functionality intergrated. And several more functions ...Aleg wrote:I know, but I want to be able to apply tasker commands after running mqncontrol and I can't do that when using mqnload, unless I call mqnload from within a batch that comtinues to run tasker.
parameters should be configurable even if its only for those that are interested in doing so
ok, I'll make them configurable just for you. What about a text file that you could modify and control would read ?nige2000 wrote:why is there problems with this ?sbgk wrote: I'm planning on having parameters for mmcss clock rates, win8.1 switches, priority and system timer which will be held in a text file read by control.
Could you also make container size a configurable parameter?sbgk wrote:I'm planning on having parameters for mmcss clock rates, win8.1 switches, priority and system timer which will be held in a text file read by control.taggart wrote:I'm about to make a new version of mqnload that has tasker functionality intergrated. And several more functions ...Aleg wrote:I know, but I want to be able to apply tasker commands after running mqncontrol and I can't do that when using mqnload, unless I call mqnload from within a batch that comtinues to run tasker.
