No, I meant that this is what chips on the mobo are being required to do - extra load on them to control the fan and also suply current to it.
I'll be replacing it with a bench supply.... I think most are saying cpu is only running a few %.
Ah, right, Fran, I'm with you - yes I think the varying current draw from the fluctuating & spinning fan could not help matters. I also think that keeping the temp of all chips as low as possible may help with sonics? I know that certain devices, SSD, RAM, CPU, GPU are throttled back when the temperature goes above certain values. I doubt varying temperatures will help any component's operation or longevity?
So the way I've been thinking for a while now is that some good heatsink on various components CPU, GPU, RAM, other cards like Wifi, graphics, etc. with a good, near silent case fan operating from an independent PS - might be a cheaper alternative to a completely fanless computer. Fanless usually comes at a premium price because of the amount of aluminium & copper used plus the shipping costs (if not built into the price). Mind you fanless cases tend to be the nicest looking!
I have a picu power supply I could live without if someone wanted to do some testing
I don't think we Should ignor tdp watts but those figures are at maximum. Utilisation and we will be nowhere near that.
And there not much difference between a 3770, 3770k 3770t only the way it's limited or not to keep tdps low
I got chatting today to a friend of mine who is a very experienced PC builder and all round IT guru. His first words were that he would be wary of the Intel mobo, simply because their BIOS tends to be not very user friendly:
http://phoronix.com/forums/showthread.p ... board-woes
He recommended an ASRock board, giving much more flexibility in the BIOS and allowing you to do things like downclock the cpu to allow for easier cooling. What do you guys think?
http://www.amazon.co.uk/ASRock-Z77E-ITX ... 475&sr=8-1
BTW, this mobo is shown in the HDplex H3 case gallery pics..... so is compatible with the fanless heatpipe cases.
Also, talked to him a bit about the fan vs fanless stuff. He sent on this link:
http://www.comairrotron.com/emi-emc-and-umf-dc-fans
More food for thought?
tony wrote: I have the ciunas set up with the zuma I am around the next few days if you want to give it a whirl. You can compare it to a very good cdp to get a comparison.
Would love to but I'm up to my proverbials until Sunday pm.
Meant to add - I have the fan rigged up to be switchable from separate supply to mobo supply.
Will be testing later tonight.
Good work, Fran.Interesting info. Look forward to your fan experiment results.
The whole EMC/RFI issue was one of the things that I had read some time ago was less of an issue in laptops. I can't remember where I read it but AFAIR the thinking was that all components were in close proximity to one another & had to be better shielded from one another to avoid issues. So maybe more careful design needed in the layout of laptop motherboards?
I also thought that they might be better for audio because of the fact that they could be run without a ground connection to mains, thus avoiding ground loops with other equipment in the audio chain.
The theory seems sound enough but in practice neither my laptop nor Tony's sounded as good as the Zuma so maybe the elimination of the fan & spinning HDD in the Zuma trumps the fan based laptop?
Hmm, next experiment (i don't mean for you) - see if some heatsinking can be rigged on a laptop to eliminate the fan?
http://www.panasonic.com/business/tough ... ok-emi.asp
Yes SSD as per Ken and somehow deal with the fan and it would be interesting to see if that works. But an I7 laptop is probably up around €700-800. when you factor in the effort of trying to cool it and then buy an ssd the zuma or the plex (which I think makes more financial sense) is the better option. Your only hope is that a more basic laptop gives the same result.
Not sure if I will still have the zuma but if I do sunday evening late(working until 7) or else monday morning if that works for you.
I think it is very worthwhile hearing it Ivor especially if you are thinking about it this year. Anyway you will get to hear it at some meet over the next while and sure when I eventually succumb dates wont be an issue. Actually got a new shand amp today primaluna prologue 2. Hope to run it with the spendors but will try it out with el34's at some point with the 57's. Just need another dac if I could find the right one! and a 'zuma' like yoke and that's me finished.
tony wrote:......and that's me finished.
Sure.
