John Dot
Post by John Dot »
Has anyone experienced issues with Win81?
I plan to upgrade my Win7 to 8.1 this weekend especially for MQn :)
BTW SBGK wich version is the best in your opinion?
Win 8.1 sounds mostly like r2 oob
Will be much better than 7
GrahamJohnMiles
Post by GrahamJohnMiles »
Forgive my naivity, but I'm a little overwhelmed by all the different versions offered for download. I get the general principle but would appreciate a little guidance on a starting point. I'm using a Intel I3 Windows 8 laptop and Ciunas DAC. What would be the best exe and control files to begin with?
Probably one of the 2.71 ones
mjock3
Post by mjock3 »
What happens is it either just stalls or it shows for up for just an instant and disappears, depending on which version I am using.
I am using an Asus P8z77-V pro mobo. I am currently in core mode, how do I stop Jplay services? Maybe that is my problem.
John Dot wrote:Has anyone experienced issues with Win81?
As nige200 says, 8.1 sounds like WS2012 R2. That is because the audio kernel files are the same in both versions and we are told were substantially rewritten by Microsoft for those versions.
8.1 obviously has more consumer interface and other 'useful' stuff added to it, but the underlying code being used by MQn is the same. 8.1 is of course much more affordable.
Jonathan
mjock3 wrote:What happens is it either just stalls or it shows for up for just an instant and disappears, depending on which version I am using.
Put mqn folder in the root c: directory
Open taskmanager and end any jplay tasks
mjock3
Post by mjock3 »
Nige,
Not sure how to taskmanager in core mode. Is there a way to open it from cmd?
Mark
mjock3
Post by mjock3 »
I found it on google. I will report back.
mjock3 wrote:I found it on google. I will report back.
No wasapi in core mode
minimal server mode is ok
