Ken Moreland wrote:Hi Aleg, good to see you here from Jplay.
I tried the clockrate registry change to 23220 today(from 10000) with 1024 sw and the sound was very nice indeed. I'm using John Kenny's Ciúnas dac and there's no buffer control (that I know of), maybe John can comment. It played a couple of albums fine but when I went to play a third album , all 16 bit, the music juddered and didn't run smoothly. i set the clock rate back to 10000 and all was well. Any ideas?
no issues ken seems ok here on the msi b85
I'm back on 23200 again and no probs at all. I changed Win32PrioritySeparation to 28 yesterday and it wouldn't play at all so I rebooted and it worked and hasn't had a problem since. Sound is superb too, the microscopic detail is unbelievable.
Aleg, thanks again, for trying to disable HPET in my Zuma, but in my "On-Board Devices", I have only "Audio" and "LAN" choices! Nothing else!
I am had a look at the bios in mine tonight too and its the same - land and audio only.....
Fran wrote:I am had a look at the bios in mine tonight too and its the same - land and audio only.....
There are always differences between boards and BIOS-versions.
My DH87RL board does have it in BiOS. So assuming you have the latest BIOS version for your, board, it seems Intel didn't expose this setting for this board for some reason.
The only option available is to disable the HighPrecisionTimer in your Device Manager in the Control Panel. That should work at least from the level of the Operating System.
cvrle59
Post by cvrle59 »
I just wanted to test if the forum is still alive...or to provoke some action here:)
John Dot
Post by John Dot »
cvrle59 wrote:I just wanted to test if the forum is still alive...or to provoke some action here:)
I assume SBGK will kick us with 24/96 MQn some day ;)
The latest 44.1/16bit versions are superb, we're all just waiting for the 24bit versions :)
Ken Moreland wrote:The latest 44.1/16bit versions are superb, we're all just waiting for the 24bit versions :)
What's the consensus (if there is one) on the best sounding of the latest versions? I thought it was 1024-sd?
For me the 1024-sw is just a nose length ahead of 1024-sd because it has just slightly more sense of space that I like.
