Headphone amp in the mix
Re: Headphone amp in the mix
Congrats Stephen,They are a lovely amp. Bigger in the flesh then they appear online. You will not be disappointed with it.
/IIRC, there are a few lovely options with the MKIII. You can change the gain to suit via dip switches under the amp - I think the impedance also.... but its been a while. I think you can also try different tubes by changing some switches underneath again - different input tubes I think.
I took out the cathode caps on mine after a recommendation by a guy on headfi. Again, its been a while, but I think it brought a little more cleaner sound at the expense of sligthly lower gain. The little bit lost wasn't an issue for me with the HD650s of k701s.
stigpepper
Post by stigpepper »
Cheers Fran,
I was lucky enough to find a review of the mkiii paried with the HD595 cans which is the set-up I will be using, so I will be able to hit the ground running with the settings.
http://www.compudio.ca/2007/06/little-d ... eview.html
I am also interested in testing the mkiii as a preamp do you know if I would have any problems running it into an integrated amp, I have a Musical Fidelity A3 Dual Mono ntegrated.
Happy Christmas,
Stephen
Frankie Lee
Post by Frankie Lee »
Any sign of the amp yet? I'm thinking of getting one for my HD650s so I'd love to hear your verdict.
There's a guy with a little dot mk4 for sale on adverts...
http://www.adverts.ie/home-audio/little ... amp/421839
Well has anyone taken it. I was going to go for one of them before settling for the cayin. If you can get him down to circa €200 it is a very good buy. Its the se also.
