Hi res download to disc problem. Help please!!
PeterK
Re: Hi res download to disc problem. Help please!!
Post by PeterK »
Hi Dave,
yours pretty much rocks from the pictures you have posted!!
I think mine might be a little sedate for some.
Peter
PeterK
Post by PeterK »
Hi Adrian,
Its an Intel core 2 Duo on the specification list, whether this is an IBM chip or not I can't say,
Peter
Adrian
Post by Adrian »
Hi Peter,
Well then the chip is a Intel and using intel CISC architecture etc.
Its just when you mentioned G5 in your original post it caught my attention. G5 was (still is) a processor developed by IBM but it used RISC architecture etc. Link below.
http://en.wikipedia.org/wiki/Power_Mac_G5
It occured to me that there could be a software confict / issue if you were trying to run more modern software on an older computer etc. However not so!!!!!!!!!!!
You could consider an alternative which would be to wirelessly stream the music via an airport express or other dac connected to your amp.
PeterK
Post by PeterK »
Markof,
As posted above there are insufficient inputs on my amp to take another source, thanks for the suggestion,
regards,
Peter
Just found this article:
http://www.linnrecords.com/linn-dvd-audio.aspx
Hope it helps.
Mark
