FS Parasound 2125 Power Amplifier
For Sale/Wanted
woodlands
Post by woodlands »
I have for sale a Parasound 2125 Power Amplifier.
Very Good operational condition.
Specs and manual below...
• 125 watts rms per channel into 8Ω, all channels driven
• 200 watts rms per channel into 4Ω, all channels driven
• 200 watts rms per channel into 2Ω, all channels driven
• 400 watts rms bridged into 8 Ω or 4Ω mono
• 35 amps peak current per channel
• Impedance selector switch for 2Ω operation
• Bridging switch for stereo or mono operation
• A/B speaker terminals with individual on/off
• 18dB/octave high pass filter, switchable 20Hz or 40Hz
• Fully discrete circuitry with toroid transformers
• Efficient, low heat design
• DC Servo and relay protection circuits
• Automatic on/off by DC trigger with looping output
• Automatic on/off by audio signal with adjustable sensitivity
• Gold-plated RCA input jacks, loop output jacks
• Heavy duty 24k gold-plated 5-way speaker terminals
• Rear-mounted gain controls; ground lift switch
• Standby, channel status, high temperature indicators
• 2u chassis;
• (W x D x H): 17.25” x 16” x 4.25 ” / 3.5” without feet
manual here :-
https://gzhls.at/blob/ldb/8/c/f/c/8c3b0 ... 9324f1.pdf
Net Weight
27 lbs , 12.3 kg
Postage within Ireland only Euro 13 !
Priced at Euro 270
photo's shows internal view and external views
parasound 2125 4 small.jpg (257.8 KiB) Viewed 1404 times
parasound 2125 2 small.jpg (107.25 KiB) Viewed 1404 times
parasound 2125 1 small.jpg (89.28 KiB) Viewed 1404 times
