Sold :- DIY Discrete R2R DAC Hat (v2) with raspberry pi 3b and power supply.
Euro 160 + Postage Euro 10
Complete with 16GB card which has volumio loaded already and a variety of
plastics panels to make it easier to handle.
( Completes with the Denafrips Ares R2R DAC and beats it
as it has the built in streamer ! )
Spec:
Hand made and hand matched 0.005% resistors
24bit 384Khz in NOS ( Non Over-sampling ) mode
Distortion: 0.01% at -10dB ( Actual measurement 0.006~0.007% )
Simple Passive RC filter
Output unbalanced RCA . 2V RMS
built-in I2S isolator
Ultra low noise regulators and LC filters
Tuned with audio grade capacitors.
Remarkable sound _ All ready to connect to your HIFI system for audiophile listening !
- You will need a network cable and left/right RCA cables to connect to your sound system.
The screen output ( not essential - works thru your screen ), is not included in this sale.
Sold : Discrete R-2R DAC HAT with Raspberry Pi & power supply Roon Ready
- r2r 6.jpg (172.26 KiB) Viewed 15456 times
- r2r 4.jpg (109.53 KiB) Viewed 15456 times
- r2r 1.jpg (145.99 KiB) Viewed 15456 times
Re: Discrete R-2R DAC HAT with Raspberry Pi & power supply Roon Ready
I will send you a message with questions. I could ask them here but they are a bit technical.
I don't seem to be able to send you a PM so could you please send me one and I will reply.
My questions are really about will it support upnp (dbpoweramp asset) and, if so, what app do I need to control it. I have a naim streamer which I need to send off for repair (the screen is wearing out) and I would like music while I wait for it to be fixed.
As your not familiar with the "Volumio" software here is the starter for you ...... I hope this provides all the basic info to you
- You’d need ethernet cable for the setup and basic router with ethernet out point.
- Connected the pi/R-2R to the router, using Etherenet cable.
- Using Network scanner in computer, find the Volumio IP Address , alternatively use Volumio.local/ to find the webpage.
- Copied it to the browser, then entered Volumio webpage / Settings mode.
- In the Settings mode, chose wifi network mode, select new wifi network (one from the provider, with pass).
-- Disconnected ethernet connection; closed web browser.
- Then Volumio visible in the iphone app or computer, communicating via WiFi. streaming/ working on Wifi.
Thanks .. I have started to read about it and will get back to you.
I will buy it (hopefully still available).
We can either meet up or use postage.
Will send PM.
Maybe I post you a cheque and you post me the item.
We can discuss
I understand that I just connect an ethernet cable and then I can switch to WiFi
After that I can login from a Linux box (I am running rocky 8, previously centos 7). I can control everything over ssh presumably.
It sounds like a fun project.
Will send PM.
We can discuss
it's still available, Just send a pm .
Re: Sold : Discrete R-2R DAC HAT with Raspberry Pi & power supply Roon Ready
Many thanks to woodlands. Bought it and really impressed.
Have the streamer working and searching for a cable (have one somewhere) and will then actually hear it. (Need phono to din).
Volumio is a Linux distribution designed for audio. I was surprised how easy it was to setup. (It was already installed and I just had to setup my own [free] account and tell it the names of the directories with my music.)
Probably starting with a bare pi would be more complicated.
Next thing is to hear it.
Think it's the modern version of the squeezbox.
