Hi, I bought this used preamp only a couple of years ago. It had some noise issue so a full check up and massive parts replacement was done by a pro technician. But there are still noise problems on one channel. I decided to give up and I will sell it for 100 euro to someone who has skills, time and will to invest in it.
Reviews at the time (90s) were very positive and the pre phono is great (MM & MC). Tubes inside are quite old and should be replaced once the problems are fixed.
Best
Rose RV-23S preamp (not fully working) - Now sold -
- IMG_20240719_232609.jpg (160.07 KiB) Viewed 8040 times
- IMG_20240719_191458.jpg (48.23 KiB) Viewed 8040 times
- IMG_20240719_191526.jpg (87.25 KiB) Viewed 8040 times
Max (spin the black circle)
Re: Rose RV-23S preamp (not fully working)
Hi
You still have the amplifier ?
How much is that ?
How much is that ?
Hi, I have just sold it on Adverts. Apologies for not updating this post.
Best
Best
