Attic Clearance
For Sale/Wanted
Sloop John B
Attic Clearance
Post by Sloop John B »
I have got the edict that the attic must be cleansed of 30 odd years of hifi bits and bobs.
What I can remember of what is up there are plenty of speaker cables, some CAT cable, loads of power supplies (2v, 5amp and loads of other iterations), a few 4 and 6 port switches, JPW mini monitor gold speakers.
I’d prefer if I could go the re-use route than the recycle route with these so if anything mentioned might be of interest…..
I’ll have a better inventory when I get up there but I know my wife won’t just want them moved to another room whilst I try to see if anyone wants them.
Dublin 6W
.sjb
Georgi
Re: Attic Clearance
Post by Georgi »
Hi, I mait have an interest in one of the switches, depending on the brand and model.
More info would be useful.
Thanks.
Sloop John B
Re: Attic Clearance
Georgi wrote: Wed Feb 28, 2024 10:55 pm Hi, I mait have an interest in one of the switches, depending on the brand and model.
Thanks.
This is still wrapped in plastic!
.sjb
Sloop John B
Re: Attic Clearance
Never used keyboard and surplus t requirement TP Link power lines
.sjb
Sloop John B
Re: Attic Clearance
Loads of Kettle power leads and Figure 8 (I think they are called) power leads
Speaker cables - bog standard, cable talk 4 (I think) bi-wire and Gale XL 315 and banana pins.
4m terminated CAT 6 patch cable
Toslink cables
Coaxial (TV) cables
4m SCART cable
Extension leads 2 x 4 plug, 1 x 6 plug.
A bewildering amount of USB cables
Phone cables (landline)
.sjb
Georgi
Re: Attic Clearance
Post by Georgi »
Thanks, I will take that switch of you.
Send me PM with phone number and address and I'll try to collect ASAP.
Thanks.
Sloop John B
Re: Attic Clearance
Some more specifics
2 x 4m Cable Talk 4 biwire speaker cable
25m length of Gale XL315
Charges or switch mode power supplies
5.6 V, 0.4 A
12 V 1.0 amp
5 V 3 A
One. 5 V 1.0 amp
7.5 V, 2.4 A
12v 1.5 amp
12V 2.0 A
Zyzel WAP 3205 wireless extender and another netgear 8 port switch
30m CAT 5 cable
5m RCA interconnect cables
0.5m and 3m Flashback mini jack cables, Cambridge audio artic interconnect
Various optical toslink cables
Russ Andrew’s Silencer
TP Link 5 port switch (limited to 100 speed so can be useful in some hifi situations)
3 port usb hub
Ethernet extender sockets
All free before they get recycled.
.sjb
Georgi
Re: Attic Clearance
Post by Georgi »
Hey John, I could get use of them 5m RCA cable and the opticals cables as well, for my sons systems.
Thanks.
Tommyboy
Re: Attic Clearance
Post by Tommyboy »
Hi John,
I'd love that Russ Andrews silencer if still available?
Warm regards,
Tom
Brutus1968
Re: Attic Clearance
Post by Brutus1968 »
Hi John,
have you an idea of the section of the Cable Talk? I can't find anything on the internet. If not too thick (max 1.5mm2) I could use them to restore a pair of old speakers that I have.
Best
Max (spin the black circle)
