Martyn Logan Summit X loudspeakers for sale
For Sale/Wanted
SteveO
Post by SteveO »
Martyn Logan Summit X electrostatic Speakers. I have owned these speakers for the best part of 10 years. They perform as well as they did when I first bought them in late 2013. They are also in good cosmetic condition. They sound quite amazing when driven from a good quality amplifier and audio source. The size of these speakers is reduced compared to a full range electrostatic panel capable of delivering real bass, as around 300hz a double woofer using a conventional cone system takes over the very low frequencies. They are also driven by its own internal amplifier which has adjustments at 50hz, and 25hz, which enables you to exactly match the balance to suit your room and taste.
Reviews can be found on the web including this one from Hi-Fi news https://www.hifinews.com/content/martin ... C2%A313000
Martyn Logan Brochure https://www.martinlogan.com/uploads/doc ... mmit_x.pdf
Martyn Logan manual for Summit X https://www.martinlogan.com/uploads/doc ... mmit_x.pdf
I am asking 6000 euros for them and can demonstrate them if required at my home near Wellington Bridge Co Wexford
ML 3.JPG (135 KiB) Viewed 3647 times
ML 10.JPG (149.39 KiB) Viewed 3647 times
Sloop John B
Re: Martyn Logan Summit X loudspeakers for sale
Post by Sloop John B »
Is this still for sale?
.sjb
Sloop John B
Thanks Tony!
Checked adverts, never thought of Done Deal.
.sjb
