John Darko used doorstops to stabilise equipment and gets asked many questions about them
https://darko.audio/2022/01/an-update- ... doorstops/
Currently Lidl has them at €3 each in their centre isle.
.sjb
Darko doorstops
Re: Darko doorstops
I use a similar one to help limit the vibrations resonating on the top of the cabinet of my cd player.
Good to see they can be used for other hifi issues. I wouldn't be too surprised to see, sooner or later, an audiophile version selling at 300 euro...
Best
Best
Max (spin the black circle)
Re: Darko doorstops
Ikea chopping board and lidl door stop, the happiness that you at least saved somewhere after spending thousands and thousands on components...
♪♫ sound sommelier ♪♫
Re: Darko doorstops
Keep an eye out for Lidl garden kneeling pads.
A pair works wonders for decoupling a REL sub from a suspended solid wood floor.
Comes in green too.
Mark
Comes in green too.
Mark
Re: Darko doorstops
Directly from REL's website... We do not recommend the use of spikes or platforms as they do not work well on RELs or any high-quality sub. Remember, the goal is to couple the subwoofer to the floor and transfer the energy into the room.
Re: Darko doorstops
On a suspended floor they will work - otherwise your floor would be like a resonating box of an acoustic guitar Been there myselfA pair works wonders for decoupling a REL sub from a suspended solid wood floor.
Re: Darko doorstops
The sub is located in my office - a converted attic.
I initially tried the sub directly on the floor but I could not adequately control the boom generated from floor resonance despite sub placement in multiple sites. I get just the right level of bass with the sub on the pads under a desk and it doesn't spill over into the rest of the house.
I guess not every listening room conforms to REL's standard model or maybe it's a matter of personal taste.
Either way the remedy did not cost an arm and a leg - maybe €10 per pad - and it's all in the analog domain :-).
Ivor's guitar analogy is spot on in my case.
Mark
Re: Darko doorstops
Probably the attic is the problem, acting like a boombox itself! I have suspended wooden floors in my house, I don't have any issues with my REL Stadium!
