3D floorplan freeware? Software?
Hello Hive mind!
I’m using a cloud-based Floorplan piece of software that seems to have been designed with only cul de sacs in mind. It was cheap and easy enough to use but limited in its ability to print (which is kinda necessary) and save outside of its big black cloud.
Back in 2005 I had a program that was far better, it cost about €3.99 on a 5 ¼ inch floppy disc! I copied it to a slightly less floppy 3 ½ disc and then to a CD. Having recently moved house I can find none of them!
So, does anyone have a physical copy of software for floor plans, one that you can switch between 2D and 3D, aerial views and ideally provide “flyovers” and “walk throughs”. It might seem a lot to expect but I had it in 2005!
Basics such as accurate measurements and a liberty of furniture etc would be nice 😊
Re: 3D floorplan freeware? Software?
that might do it alright Thanks boss
Ivor wrote: Thu Jul 14, 2022 11:09 pm
Nooo... too restrictive...
www.floorplanner.com
Flexible and I think I can export plans
If you need this kinda software...
Handy to know
