Grado PS1000 headphones
For Sale/Wanted
Practically perfect condition. Little used.
https://www.adverts.ie/26563709
Re: Grado PS1000 headphones
I will let these go for €600 on Tir na HiFi 🎶
Gerry, do you still have these? Can I ask, what's the bass line (in terms of depth)? Are they comfortable to wear? Is the sound leakage really bad?
I might be in the market for headphones at some point soon...
Hi Simon
I think they are quite natural sounding overall.
They do leak a bit.
Happy to loan them to you anytime so you can check them out
Thanks Gerry. I'm away for a couple of weeks soon, but if they're still there when I come back I might take you up on that
Gerry D wrote: Tue Jun 28, 2022 3:43 pm Happy to loan them to you anytime so you can check them out
Hey Gerry, does that offer still stand?
Here's the situation: I now have my home organ up and running, and for obvious reasons nobody wants to listen to me practising for hours on end. I'm in the market for really good headphones, and these certainly tick that box by all accounts. My only concern is that there's a certain amount of movement involved when playing, and most reviews I've read suggest you'll need to keep your head pretty still or else the sheer weight of them will have them slipping.
Do you still have them?
Si
Hi Simon
Yes, still available. And. You’re very welcome to try them.
How to get them to you ?
Talk soon,
Gerry 🎶
