Now Sold: MBL 7006 Integrated amplifier - immaculate
For Sale/Wanted
Bannjo
Post by Bannjo »
I am selling this lovely German made integrated amplifier, a recent purchase that unfortunately/ frustratingly doesn't get on with my Wilson benesch trinity speakers. Therefore I am reluctantly moving it on.
This unit was manufactured in 2013, retailed at around £4999 when new. I'm asking £1850 + post.
This is a suberb example of German engineering, with solid build quality and reliability as well as a piece of visual art and I genuinely cannot see a mark on it.
Finish : Piano Black / Gold
Original boxes and packaging
Upgrade MBL full aluminium remote control
User Manual
Mains Cable
Benefits from the upgraded full function aluminium remote control, and has a very high end headphone amplifier built in.
Sound is quite wonderfully organic, with immense presence and fluidity - very three dimensional sounding amplifier - a rare find on the pre-owned market for sure.
What the manufacturer says :
The MBL 7006 is an excellent choice for music enthusiasts seeking a compact integrated amplifier. Produced with know-how and a passion for detail, its technical qualities, solid workmanship and attractive design makes the 7006 first choice for music lovers who want maximum listening enjoyment at manageable costs. Its exquisite visual appeal is matched by sophisticated engineering that puts it in the genuine high-end range of the market.
The MBL 7006 integrated amplifier is rated at 120 watts per channel but uses the same circuits as the MBL 8006 B amplifier and 4006 preamplifier combo that has a great ability to drive low sensitivity speakers.
The clarity and precision of sound will blow the minds of listeners.
The amplifier has unbelievably clear, detailed and vivid sound. It lends power and natural quality to the music as never before experienced in this class. With the signature MBL's warm, rich and and dynamic characteristics, other solid state amplifiers pale in comparison to the MBL 7006. Usually only tube amplifiers can give rich sounds, but the MBL 7006 takes that a step further, surpassing them in dynamism and bass control that will even surprise the tube lovers of the world.
SPECIFICATIONS
Inputs..............................................6 inputs
          ..............................................1 x XLR, 2 x CD, 2 x high level, 1 x processor
Outputs........................................... Fixed out, Headphone Out (front panel)
Frequency Range............................DC - 400kHz
Output Level....................................1 Veff to 10 Veff max
Output Impedance...........................100 ohms
Noise Distortion...............................<0.001%
Input Sensitivity................................315mV
Signal to Noise.................................98/101dB, 1V/25 ohms
                      ....................................CD: 103/107dB, 1V/25 ohms
Input Impedance...............................High level: 50k ohms
                       ...................................Bypass: 10k ohms
                       ....................................CD: 10k ohms
Power Section
Rated Power....................................120 watts (8 ohms)
                 ........................................185 watts (4 ohms)
Output Voltage.................................35V max
Output Current.................................20A max
Input Sensitivity................................1.5V, 185 watts, 4 ohms
Channel Separation..........................90dB
Signal-to-Noise Ratio........................Unweighted: 111dB
                                 .........................A-weighted: 115dB
Frequency Response........................DC - 135kHz / -3 dB
Total Harmonic Distortion + Noise......<0.006%, 4 ohms, 1 kHz, 50 watts
Damping Factor................................300 at 4 ohms
Power Consumption..........................4VA, sleep mode
                                ..........................120VA, idle mode
                                ..........................450VA, maximum
Line Voltage......................................230 Vac 50/60 Hz (single voltage)
                      ....................................115 Vac, 50/60 Hz
Dimensions(w x d x h).......................45 x 41 x 12 cm
Weight...............................................15kg
Looking for £1850, collected from Belfast, will post at buyers cost / responsibility as still have original packaging
MBL Back2.jpg (79.67 KiB) Viewed 1028 times
MBL Front1.jpg (83.84 KiB) Viewed 1028 times
