Anyone try "Tonar-Tacky-Rolling-Record-Cleaner" ?
Post by james »
https://www.amazon.co.uk/Tonar-Tacky- ... y&sr=8-1
Has anyone any experience of the Tonar record cleaner ?
James
Re: Anyone try "Tonar-Tacky-Rolling-Record-Cleaner" ?
james wrote: Tue Apr 16, 2019 3:23 pm https://www.amazon.co.uk/Tonar-Tacky- ... y&sr=8-1
James
I have to admit I've never tried one, I'd be more afraid of what it would leave on the surface than what it would lift out! A good anti-static brush would be a safer bet.
I'd use this before I'd buy that
https://www.amazon.co.uk/dp/B00CP1A6H4/ ... 8f44a51c10
The other option is the spin clean or one of its variants, but the money is a good bit higher
https://www.amazon.co.uk/dp/B008EBS9G4/ ... 3I97UDKN6D
After that you're into either wet vacuum or ultrasonic machines at much more money and hassle again
Post by james »
Thanks for the responses ..
I have just got my record deck working again (Linn-Axis) and I have a number of second-hand (charity shop) LP's I would like to clean. I am happy to risk damaging them but not doing something that would damage the needle (Its an Ortofon MC-15 Super-II moving-coil).
I think the Tonar is a copy of ... the Nagaoka record cleaner ..
https://www.amazon.co.uk/Nagaoka-CL- ... 1&sr=8-1
I have also seen people suggesting cleaning records by coating them with Resin-W (or similar) and then peeling it off ..
James
I really wouldnt try the wood glue thing, not on records i liked any way!
I have a record cleaning machine if you want to get them cleaned, I'm in Dublin 6. Get you started anyway!
There are cheaper versions of that disc cleaner on amazon- down to €40 or so. Ivors offer might be a good way to get going at least?
Post by james »
Ivor wrote: Wed Apr 17, 2019 10:30 am I really wouldnt try the wood glue thing, not on records i liked any way!
Thanks for the offer. Much appreciated. I won't take you up on it for the moment.
Here is a link to the glue cleaning option ...
http://www.openculture.com/2014/11/ho ... ue.html
