Converting Files: WAV to FLAC
Rocker
Post by Rocker »
I have a few ripped music folders in WAV format which I want to convert to FLAC. The disks are in storage (in other words in a box up in the attic) and if there is a simple foolproof way of converting them on my computer, I am all ears. I normally rip disks with EAC and usually process the output to FLAC but for some reason or other I opted not to compress them, hence I am left with WAVs. Which play of course but have no Metadata info. Thanks.
Beware of a thin chef!
Re: Converting Files: WAV to FLAC
Theres a free bit of software Xrecode that I use for this - it will convert pretty much any format to any other format and give you lots of options along the way.
