18650 battery question
Thought I'd post this here as one of you guys will surely know.
We got our daughter a clock radio recently, and the colour (pink) was more important than the functionality, so we ended up with a slightly bizarre device that I can barely work myself: https://www.amazon.co.uk/KABB-Calendar- ... B07HF7D5DN
Anyway, it's powered using a USB-cable to whatever, but there's a slot for a battery backup too and it keeps flashing at me to remind me there's nothing in there. I had my AAs ready to go when I realised the slot is actually for a 18650. Now, I know nothing about this, I'm reading they're not really standardised, I'm reading the usual horror stories about blowing up (which would be bad in a 7 year-old's bedroom) so could somebody here just tell me what to buy and where to buy it?!
Ta.
Re: 18650 battery question
Have some here
Aha, I was hoping you'd be along, Nige. Can we do a deal?!
giant haystacks
Post by giant haystacks »
my led torch has just went a bit funny and i flashing on and off so i said i will screw it apart and check out tirna hifi and snap i was looking at 18650 post and battery in my torch at the same time but it is not like the 18650 in my head torch with the standard plus and minus this has some components down the side of the battery and leads red and black which plug into socket in torch so i am not sure what to do i may report back here maybe for words of wisdom
Think I've 4 new Sanyo cells here how many u need?
And Yes my stock of parts is well out of hand
I only need one, but tbh I'm not sure if there's a particular "version" I need or what.
Diapason wrote: Wed Dec 12, 2018 2:30 pm I only need one, but tbh I'm not sure if there's a particular "version" I need or what.
Battery Name: Sanyo 18650 cylindrical lithium-ion batteries
Battery Type: UR18650NSX
Battery Specifications: 18 * 65 (MM)
Battery material: Lithium-ion (Li-ion Lithium Ion Battery)
Battery Voltage: 3.6V
Battery internal resistance: ≤15mR within
Minimum Capacity: 2500mAh
Nominal Capacity: 2600mAh
Battery Weight: 45.8g
was bout 8 euro each so 8 plus post ok?
That's lovely ta. I'll PM you.
