Oppo 93 BR/DVDA/SACD Player Multiregion DVD
For Sale/Wanted
mossym
Post by mossym »
hi
have an Oppo 93 for sale , owned by me from new. Generally a 5 star product in most reviews, it's a battleship of a disc spinner, offering superb performance across bluray, dvd audio, sacd and streaming (from nas). cannot rate this highly enough, only changing to move to the latest version that offers 4k UHD support
The unit did have a blurry multi region mod fitted, which got disabled by a firmware update. as such, it is currently region A for blu-ray(US), but i can set it back to region B (UK) if user prefers. vast vast majority of discs are region free anyway, think i hvae only a handful out of a few hundred that are coded but happy to set to whatever the buyer wants. it's multiregion for dvd at the moment.
comes with original remote and box, and is in perfect condition. looking for 225 euros
review: https://hometheaterreview.com/oppo-digi ... -reviewed/
Specs:https://www.oppodigital.com/support/blu ... pport.aspx
Disc Types* BD-Video, Blu-ray 3D, DVD-Video, DVD-Audio, AVCHD, SACD, CD, HDCD,
Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE, BD-R/RE DL
BD Profile BD-ROM Version 2.4 Profile 5 for 3D (also compatible with Profile 2, Profile 1 Version 1.0 and 1.1)
Internal Storage 2GB (Approximately 1GB available for BD-Live persistent storage. Actual storage varies due to system usage)
Output Analog Audio: 7.1ch, 5.1ch, or stereo
Digital Audio: Coaxial, Optical
HDMI Audio: Stereo, up to 7.1ch high-resolution PCM, up to 5.1ch DSD, bitstream or LPCM conversion of Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio.
Analog Video: Composite, Component Video (Y/Pb/Pr, 480i/480p, 720p/1080i available for non-restricted content only)
Digital Video: HDMI with HDCP (NTSC: 480i/480p/720p/1080i/1080p/1080p24, PAL 576i/576p/720p/1080i/1080p/1080p24)
Video Characteristics Composite Video Amplitude: 1.0Vp-p (75Ω)
Component Video: Y: 1.0Vp-p (75Ω), Pb/Pr: 0.7Vp-p (75Ω)
Audio Characteristics** Frequency: 20Hz - 20kHz (±0.3dB), 20Hz - 96kHz (±2.0dB)
Signal-to-Noise Ratio: >110dB (A-weighted)
THD+N: < 0.002% (1kHz at 0dBFS, 20kHz LPF)
General Specification Power Supply: ~ 100V - 240V, 50/60Hz AC
Power Consumption: 35W (0.5W Standby)
Dimensions: 430mm x 311mm x 79mm, 16-7/8 x 12-1/4 x 3-1/8 inches
Mass: 4.9kg / 10.8 lbs
Operating Temperature 5°C - 35°C
41°F - 95°F
Operating Humidity 15% - 75%
No condensation
mossym
Re: Oppo 93 BR/DVDA/SACD Player Multiregion DVD
Post by mossym »
sorry, corrected the price, had it entered higher than i intended to
bod
Post by bod »
Definitely interested in this Mosssym! Where are you based? I can collect if around Dublin area. PM me and we can discuss. Cheers, Dave.
mossym
Post by mossym »
hey, i'm just north of limerick, but i'm in dublin a few times over the next few weeks, including this sunday, i'm going over to the audio show in bristol and will be flying back into dublin airport sunday afternoon.
only thing is by this weekend i cannot have it back to region b, but if you were after a region a or wanted to make it multiregion yourself that might not be an issue
will be up again in march for the bellx1 gigs
mossym
Post by mossym »
now sold
bod
Post by bod »
Cheers! PS: Do you know of an option for android remote apps? The Oppo one doesn`t work!
mossym
Post by mossym »
sorry, i really only used it as a disc spinner, never bothered with an app.
