Hi all
Anyone know anyone that might take a look at an amp that has developed a slight transformer buzz? Prefer north east area.
Recommend a service centre?
Re: Recommend a service centre?
Rodney Hanna in Enniskillen is a very knowledgeable guy with a lot of experience with audio gear.
hi,
try this one, but the guy does not seem to be answering the phone, newer! so I can not recommend it.
http://audiorepair.ie/
HI rodney is my friend he is in enniskillen but he wont want to see any repairs until new year he is recognised as the best up this part -there was another engineer called jeff croynin in lisburn but he has retired now
Ok, thanks. No rush. I’m not even sure if it’s a fault but would like to get it checked out.
Is the buzz constant, or does it come and go, as mine did, which I eventually traced to DC on the mains?
