4 X Audiophile DJ Studio Acoustic panels
Condition: New (still in the box)
Asking price: €95
To Be Collected in Celbridge (Co. Kildare)
Product Description:
Acoustic panels combining the function of absorption and reflection of sound through the use of acoustic foam and the front of the dispersion plate. Well in any room where there is a problem with reverb and other adverse acoustic in the medium-high frequencies. With its low weight and simple construction these panels are easy to install.
Specifications :
Effectiveness - medium and high frequencies
Type of front plate - plastic material, glossy, thickness 2 mm
Dimensions: 50 x 50 cm
The height of the whole panel : 3.7 cm
Acoustic foam thickness : 3.5 cm
Acoustic foam type : PG-1 - Lightweight
4 X Audiophile Acoustic panels SQM Glossy White
