Looking for good starter turntable
For Sale/Wanted
TrickyDicky
Post by TrickyDicky »
A buddy of mine is looking for a good starter turntable (c. €200-€280) but I can't find anything out there at the moment that I can recommend to him. Anyone clearing out, or know of something that's available?
Re: Looking for good starter turntable
http://www.adverts.ie/home-audio/projec ... e/13746053
Something like this? Looks like he'll let it go for €180
TrickyDicky
Thanks for response. Had seen that ok, but notice that you can get it brand new & delivered from richersounds.ie for 219 (new stylus, guarantee, etc.) which would be still inside his budget. Are you familiar with the Essential II?
TrickyDicky wrote: Thu Sep 21, 2017 9:23 pm Thanks for response. Had seen that ok, but notice that you can get it brand new & delivered from richersounds.ie for 219 (new stylus, guarantee, etc.) which would be still inside his budget. Are you familiar with the Essential II?
Always find some of those ad's hard to understand. Have seen ones even closer to the new price.
TBH I'd go new if he can get it at that price. As far as I know Richersounds.ie did/do a discount for registered Boards users. Not familiar with the Essential II but Projects are generally simple to set up and get going straight out of the box.
I've been using a Project for the last few years and am very happy with it: http://www.hifihut.ie/turntables-irelan ... black.html impressed over more expensive ones when I was buying it and got a good deal from Hifi Hut
Thinkfloyd
Post by Thinkfloyd »
I have a Pro-ject Debut Carbon DC which I've just upgraded. It's less than a year old, and I can supply either an Ortofon Alpha or 2m Red cart fitted. Fully boxed with all the original bits.
Would be looking to get around the €325 mark for it with the 2m or €300ish with the Alpha.
TrickyDicky
Thinkfloyd wrote: Tue Sep 26, 2017 4:39 pm I have a Pro-ject Debut Carbon DC which I've just upgraded. It's less than a year old, and I can supply either an Ortofon Alpha or 2m Red cart fitted. Fully boxed with all the original bits.
Just PM'd you,
R
