Anti-static Record Cleaning Arm
For Sale/Wanted
Tadzo
Post by Tadzo »
For sale:
New Anti-static Record Cleaning Arm
(Hi-Fi Choice Recommended):
https://we.tl/wkWiodLSZn
This simple and effective arm cleans your records, reduces record and stylus wear by keeping those grooves dusted while you play, and eliminates static build-up. The cleaner will not interfere with tracking force and anti-skate like the brush that attaches directly to your tonearm, as it mounts on the opposite side of your deck, thereby not interfering with any of the tonearms operations.
FEATURES:
Very easy to install on any turntable with a plinth, very easy to use.
The fine fibre brush cleans the record as it rotates.
The conductive path from the tips of the carbon fibre brush to the ground wire dissipates static charges and reduces the attraction of airborne dust during playback.
Reduces record and stylus wear. Eliminates static build up.
http://www.adverts.ie/home-audio/anti-s ... m/10531085
I'm asking 20 eur
Last bumped by Tadzo on Thu Jun 16, 2016 1:10 pm.
