SOLD>>>Subwoofer Bowers&Wilkins ASW 610<<<SOLD
For Sale/Wanted
Tadzo
Post by Tadzo »
For sale:>>>>>SOLD<<<<<
Multi Award winning subwoofer powered by internal 200W amplifier. Perfect condition, supplied without manual & box.
According to WhatHiFi Magazine…..
“Best subwoofer up to £700, Awards 2011. The B&W ASW610 sounds bigger than it looks and more expensive than its price-tag”
What HiFi Group Test Winner
"The ASW610's edge lies in its lethally effective blend of power and poise, muscle and musicality. It can deliver bass with subtlety and expression".
Euro 430 or near offer.
Postage costs (IRL):
20 eur
Description: Active closed-box subwoofer system
Drive unit: 1x ø250mm (10 in) paper/Kevlar® cone long-throw
Frequency range: -6dB at 20Hz and 25/140Hz adjustable (EQ at A)
Frequency response: ±3dB 27Hz - 40/140Hz adjustable (EQ at A)
Bass extension: -6dB at 20Hz (position A) -6dB at 25Hz (position B) -6dB at 30Hz (position C)
Amplifier Power output: 200W
Rated power consumption: 40W / 0.5W standby
Input impedance: 33kΩ
Signal / noise: >90dB
Functions: Volume level - line in
Volume level - speaker in Low-pass filter frequency Low-pass filter bypass Bass extension Bass roll-off alignment Auto sense on/standby Phase switch
Inputs: Line in (RCA Phono) Speaker in (Binding post) 12v trigger (3.5mm jack)
Low-pass filter: Active 4th-order, variable cut-off frequency
Dimensions:
Height: 310mm (12.2 in) not including feet
Width: 310mm (12.2 in)
Depth: 375mm (14.8 in) including grille and controls
Net weight: 12.5kg (27.6 lb)
