Sold Copland CSA 28 Hybrid Integrated Amplifier Sold
For Sale/Wanted
woodlands
Post by woodlands »
Now Sold
The Copland CSA 28 is a hybrid integrated amplifier with a valve based pre-amp and a Mosfet based power amp all in one box.
Combine well to produce a fantastic / dynamic sound.
In excellent operational condition, supplied without remote.
I have owned it for many years, but only used it sparingly, especially over the last 4/5 years when I have rarely had the time to
listen to music at home, hence the sale.
Euro 675 or near offer.
Plenty of excellent reviews on the net - e.g. see: http://www.audioasylum.com/reviews/Inte ... 06873.html
Specifications:
Output power: 2 x 60 W into 8 ohms
Phono Input impedance: 47 k Ohms
Phono Sensitivity: 3 mV
Line Input impedance: 33 k Ohms
Line Sensitivity: 130 mV
Power bandwidth: 5 Hz - 30 kHz - 3 dB - Frequency Response: 5 Hz - 120 kHz - 3 dB
Harmonic distortion: Better than 90 dB
Hum and noise : Line - better than 90 dB
Hum and noise : Phono - better than 76 dB
Phase: Non inverting
Vacuum tubes: 2 x 6922 (All valves are hand selected and matched to ensure identical characteristics)
Grounding: Separate grounding on power supply. Signal/chassis connected to signal ground.
Power Consumption: 250 watts
Dimensions (WxHxD): 430 x 125 x 375 mm
Weight: 13kg
copland 3 small.jpg (82.28 KiB) Viewed 1173 times
copland 2 small.jpg (80.45 KiB) Viewed 1173 times
copland 1 small.jpg (106.37 KiB) Viewed 1173 times
