for sale - Aiwa AX 7600 Vintage Stereo Amplifier
For Sale/Wanted
pm2097
Post by pm2097 »
Aiwa AX 7600 Vintage Stereo Amplifier, fantastic condition
*******This is a high end piece of kit manufactured BEFORE Aiwa went downhill*******. Really heavy piece of kit and very well built. 13.5 kilos
Country: Japan
Tuning range: FM, MW
Power output: 40 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 70kHz
Total harmonic distortion: 0.2%
Damping factor: 50
Input sensitivity: 2.5mV (MM), 150mV (DIN), 150mV (line)
Output: 150mV (line), 0.4mV (DIN)
Speaker load impedance: 4Ω to 16Ω
Dimensions: 450 x 162 x 365mm
Weight: 13.5kg
Year: 1977
This is a superior piece of kit, with high end components. Seriously good hi fi, and rare also. Powerful, sweet audio, non fatiguing listen. Overall this is in wonderful condition for its vintage. This was manufactured in the late 70's, before the downturn in Aiwa's quality. Really makes speakers sing
this has connections for 2 sets of speakers, so you can bi wire your speakers if you have speakers of that type. The spring clip connections have been upgraded to modern banana plug type connections, so either bare wire or banana plugs will work to speaker set A. speaker set B is 2 pin din connections. I have already sold 2 sets of these paired with mission 752 freedom speakers, the match was superb.
http://www.radiomuseum.org/r/aiwa_stere ... _7600.html
300 euro - can be listened to / demoed
