For Sale - TDL RTL3 Mark 2 Transmission Line Floor Speakers
For Sale/Wanted
pm2097
Post by pm2097 »
******i have bought a 30 euro sheet of 20mm thick reticulated black speaker foam and will be fitting to the bass ports later****** (original foams perished over time, which is totally common, and is being replaced by correct type of speaker foam))
TDL RTL3 Mark 2 Transmission Line Floorstanding Speakers
These are proper, original TDL speakers,before the company name was sold to a mass producer. For anyone who doesnt know, the Bass is PHENOMENAL with these speakers, due to the transmission line design
Specifications :
System..........................................Reflex transmission line loading floor standing
Drive Units.....................................Two 172 mm loaded polypropylene cone with forward roll
- Base Units...................................rubber surround & phase plug - long throw double wound coil on kapton former with bump back magnet yoke
- Tweeter........................................19mm soft dome ferro-fluid cooled
Crossover.......................................Electrical 2 way second order network
Frequency Range............................35Hz - 20kHz
Sensitivity.......................................90dB at 1m for 1 watt
Impedance......................................8 ohm nominal
Amplifier Requirements....................20-120 watts per channel
Wood finishes.................................Ash black or rosewood
Dimensions(w x d x h).....................20 x 39.5 x 91 cm
Weight...........................................16kg per side
500 euro
collection only as these are enormous and very heavy
