Vintage KEF Celeste IV Speakers - with high gloss white custom spray paint finish & RARE red covers - 250 euro
******note these do not have stands with them********* will deal on the price because of this
http://www.hifiloudspeakers.info/Anatom ... ualp1.html
http://www.kef.com/uploads/files/en/mus ... s_1965.pdf
http://www.kef.com/html/gb/explore/abou ... index.html
These are just superb sounding speakers, wonderful low end, great soundstage, and look totally amazing now. I have given them 5 coats of spray paint, 2 undercoats, and 3 gloss white. Its high gloss, so it has a beautiful shiny finish.
**note KEF logos are there, they are just covered by masking tape, will be removed when fully dry***
Specification: Celeste IV
System Type: Two-way, bookshelf/stand-mount
Enclosure type: Closed box
Size: 52.4 x 26.5 x 23cm (20.6 x 10.5 x 9 inches)
Weight: 8.1kg (18 lb)
Input Impedance: 8 ohms
Rated maximum power: 50W programme
Amplifier Requirements: 10-50 watts per channel into 8 ohms
System resonance: 68Hz, Q=0.7
Frequency response: 70-20,000Hz +/-3dB
Sensitivity: 86dB spl at 1m for pink noise input of 1W
Maximum output: 103dB spl on programme peaks under typical listening conditions
Finishes: CUSTOM WHITE GLOSS SPRAY PAINT
Grille: red
System: SP1145
Drive units: B200 bass unit (SP1070), T33 tweeter (SP1068)
Crossover: SP1108
System: SP1145
Drive units: B200 bass unit (SP1070), T33 tweeter (SP1074).
Crossover: SP1136
collection only
250 euro
For Sale - Vintage KEF Celeste IV Speakers - gloss white
- IMG_0986.JPG (30.52 KiB) Viewed 442 times
- IMG_0985.JPG (30.08 KiB) Viewed 442 times
Re: For Sale - Vintage KEF Celeste IV Speakers - gloss whit
Are these the same ones that are on Done Deal for 250 ?
He who dies with the most expensive HiFi wins
Hi yes indeed they are. I'll change that price I've been cutting and pasting from my adverts ads sorry. I'll alter it in adverts also. It was in the body text you see.
