Fanless Cooler
Re: Fanless Cooler
motberg wrote:Hi,
My current server is a Gigabyte GA-Z87M-D3H, I5-4670t, NOFAN CR-95c, 2x4 GB Corsair, TeraDak 210 ATX LPS with separate 5V line for PPA V2 USB card, the 64GB OS SSD is using a PPA battery pack, PS/2 mouse, USB back-lit keyboard, on-board video, 256GB SSD for music (all WAV files), both SSD's use PPA red thin SATA cables. WIN2012 and AO (1A, no USB optimization).
Been using this NOFAN CR-95c basket thing for about 4 months with no problems.. when I was researching this - the CR-95 got much better reviews than the cheaper model IIRC...
ive a cr-95c in my desktop pc
recommended but still think a lump of alu or brass will do it
rickmcinnis
Re: Fanless Cooler
Post by rickmcinnis »
I enjoy the continuing brass "theme" but copper is superior in every way as a conductor of heat plus I suspect it has better damping qualities.
Cannot imagine a lump of any metal being a good heatsink - not to say it should be thin and spindly.
I have used 8mm copper plate for heatsinking many times, but not with CPUs. Made for a very good heatsink for chipamps when I was using those. It does not ring.
Re: Fanless Cooler
rickmcinnis wrote:I enjoy the continuing brass "theme" but copper is superior in every way as a conductor of heat plus I suspect it has better damping qualities.
Copper is better like a conductor, but I never like it either under or on top of the equipment! It suck the life of music, deaden the sound!
On the other hand, brass is the best and my favourite material that I tried!
rickmcinnis
Re: Fanless Cooler
That is interesting.
Must admit I have never tried comparing copper and brass - one of those assumptions that copper is best and that is that!
Sucking the life out of music is one of those things that depends on how lively the system was to begin with! I must admit I have not detected the effects you mention - but your comments make me want to explore further.
Re: Fanless Cooler
my haswell cpu consumes less than 10w at 800mhz heat aint a big issue
the brass thing for anti-vibration is a sort of running joke
we've no idea why it works not to mention better than other materials
Re: Fanless Cooler
motberg wrote:Hi,
Hi motberg thanks it looks a nice thing alright and if I end up needing something it is high on the list but as Nigel suggests I will see what happens when I manage to get it built and running.
Brass is in situ in the streacom case(just a square the size of the cpu cover. Adam loves the stuff and we had to try. I can't say whether it does work or not but there is a logic to it! Well our logic!!
rickmcinnis
Re: Fanless Cooler
nige2000 wrote:my haswell cpu consumes less than 10w at 800mhz heat aint a big issue
That is why I referred to the "theme" since I thought it was something of a joke at least as a cpu cooler!
Well, it is winter and I am sure Ireland is cooler than Georgia in the summer. Heat does become an issue! Maybe one can actually use such a thing?
Of course, there are always fans! Whether a fan blowing on a big lump of brass would cool a CPU is something I do not know. There are some very quiet fans.
Damping the motherboard/cpu with the weight of a brass block is worthy of consideration. But I would worry one might lose the cpu, even at 800 hhz, with a brass block as the cooler.
Sebna, are you using nothing more than a brass block on your cpu? Even in the summer? Forgive my laziness at not looking at the old posts.
Re: Fanless Cooler
well you could use the stock cooler remove the fan and place your brass block on it
rickmcinnis
Re: Fanless Cooler
nige2000 wrote:well you could use the stock cooler remove the fan and place your brass block on it
Stock cooler? No way!
I would think applying some extra pressure to the block/.cpu interface (I could not think of another word; makes me cringe, too) would be needed.
I will have to start looking for some brass chucks and see what happens. I certainly am skeptical of a heatsink that can sound like wind chimes. Which every one I have ever used could double as.
Re: Fanless Cooler
rickmcinnis wrote:I would think applying some extra pressure to the block/.cpu interface (I could not think of another word; makes me cringe, too) would be needed.
:) wind chimes! Definitely out now but will probably wimp out and put some kind of pipe arrangement. The ebay ones linked seem reasonably priced.
BTW I had a lump of granite on top of the brass with no issue but see the worry.
